Date/Time: Mon, 17 Mar 2025 01:16:03 +0000
sierra charts says not responding
View Count: 444
[2022-09-01 17:53:31] |
User84163 - Posts: 17 |
Everything was working fine and i tried to open a chart for NQ and now sierra wont work just says not responding and keeps disconnecting and downloading data
[2022-09-01 18:48:27] |
Sierra_Chart Engineering - Posts: 18801 |
Refer to: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.16 - What to do if Sierra Chart is in a frozen state for an extended time due to extended high CPU usage caused by an automatically or manually opened Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
