Date/Time: Mon, 17 Mar 2025 01:13:21 +0000
Renewed package and data but still getting delayed data
View Count: 389
[2022-09-01 13:58:23] |
Jaydtrade - Posts: 88 |
I renewed my data, however its been well over 20 minutes and still getting data 10 minutes behind please help.
[2022-09-01 14:14:22] |
Sierra_Chart Engineering - Posts: 18801 |
The reason you are not getting real-time data from the CME Group of exchanges is that you activated the Non-Professional exchange fees, but you have not verified in the last month that you have a live, funded, futures trading account, which the CME needs in order to allow you data at the lower priced fees. Refer to the following for instructions on how to connect once a month to your *live funded* trading account to qualify for the lower-priced exchange fees: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees If you do not have a funded trading account or one with a supported trading service, then refer to this solution: Easy Solution to CME Funded Trading Account Requirement Consider the above solution to avoid this problem in the future. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-01 14:18:06] |
Okay you're right, I totally forgot to have my broker do this
