Date/Time: Tue, 18 Mar 2025 02:25:47 +0000
Loading Spreadsheets at Startup Automatically?
View Count: 495
[2022-09-01 11:49:10] |
ycomp - Posts: 321 |
Is there any chance we could get a setting to define Spreadsheets to load at Startup? similar to how you can load chartbooks?
[2022-09-01 12:56:24] |
Sierra_Chart Engineering - Posts: 18812 |
Yes this has always been supported: General Settings Window: Startup (Global Settings >> General Settings >> General) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-01 12:56:36
[2022-09-02 10:55:45] |
ah thanks, for some reason i was thinking it was only chartbooks. good to know spreadsheets are also supported
[2022-09-11 10:28:50] |
are you sure this works with Spreadsheets? I can't figure it out.. I've added several (they are all in the DATA) folder to the list of files to open at startup. but none of them actually open. I'm on 2408 Date Time Of Last Edit: 2022-09-11 10:29:06
[2022-09-11 16:46:35] |
JohnR - User831573 - Posts: 320 |
It works for me. Could the spreadsheets possibly be minimized? They do not show up as a different tab in the control window. On startup I have a chartbook open and also opens 2 SSs. One is visible and the other is minimized. Hope this helps, JohnR Date Time Of Last Edit: 2022-09-11 16:50:44
