Date/Time: Mon, 17 Mar 2025 02:39:31 +0000
Comex Micro Copper data will not load
View Count: 455
[2022-09-01 10:17:43] |
VolTrader73 - Posts: 136 |
Hello. Trying to load a year or two load Comex MHG (micro copper). The chart format like others that work is continues contract date rule back adjusted using DEC 2022 contract. I get these errors. I close SC and deleted all MHG files I found in the data folder. Reopen SC and load new chart but to no avail. I try to change the begin data to 050521 but SC dosnt let me it changes back to 050522 See screenshots Please advise |
[2022-09-01 10:29:05] |
Sierra_Chart Engineering - Posts: 18801 |
This is new contract. So there is only data going back at most about three months or so. You need to use the HG contract instead. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
