Date/Time: Mon, 17 Mar 2025 02:42:20 +0000
Cummulative pulling and stacking
View Count: 723
[2022-09-01 07:17:27]
Calinorth86 - Posts: 15
How can I change the color of the cummulative pulling and stacking text. It is currently set to black and I can't See it
imageScreenshot 2022-09-01 001153.png / V - Attached On 2022-09-01 07:16:12 UTC - Size: 20.6 KB - 166 views
[2022-09-01 16:46:06]
John - SC Support - Posts: 38678
The setting is called Chart DOM Total/Percentage Text on the Graphics Settings window.
If this is a Trade DOM, then it would be Trade DOM Total/Percentage Text.
Although it is unlikely that it is set to Black, as it is set to White by default. Most likely you just need to scroll up higher/lower to find the highest/lowest Pulling/Stacking entry, and the sum is above/below that level.
