Date/Time: Tue, 26 Nov 2024 13:52:44 +0000
white shadows on black
View Count: 1173
[2014-05-14 14:05:53] |
User51148 - Posts: 8 |
Why in the BLACK CHART BACKGROUND there are TWO STUPID WHITE LINES surrounding chart? Why these lines could not be black or dark on the black background? Why on some lines {box borders]can I change color [by setting PC]and on others cannot? I do not need to see any of these white eye catching borders on the multiple charts. It is ENOUGH for me that I know where these borders SHOULD be. Just in case the cursor change its shape over them. It is enough to have time or value scale to see where one chart ends and other begins. There is no need for visual line borders. The same is valid for DOM. If I can disable title bar, scroll bar , chartbook tabs,etc. why cannot I disable contrast borders? |
[2014-05-14 17:04:30] |
It sounds like you are referring to the border of the chart windows. This cannot be removed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-14 17:04:43
[2014-05-14 18:04:39] |
If you cannot remove border of the chart widows, so there are following suggestions: - new option: to change the border color of these chart windows or - removing the REVERSE COLOR CONDITION according to the background {that is color will be set by setting PC not by setting sierra chart} or - new option:widen the color of the chart background over the border of the chart widows {that is the chart background and the border of the chart widows will have the same color} |
[2014-05-15 05:20:34] |
The chart border color can be changed through the Windows color settings. What reverse color condition are you referring to specifically? Please post an image of this and point it out. We cannot widen the color of the chart background over the window border. That is completely impossible. And we would never attempt to try to figure something like that out. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-15 11:18:05] |
Every chart has three thin borders{shadows]. !. inside border - color can be changed in the Chart....Graphics setting. 2. middle border - color of this border can be changed only by changing background. On the black background is the color of this border stupidly white. 3. outside border - color of this can be changed by setting the PC. If I do not use the Status Bar or Toolbars, so the middle border is bellow the name of the chart and the outside border is over the name of the chart. I am keep writing about the middle border that is on the black background only white line {between two charts]which color cannot be changed. I want the color of the middle border {as an option] could be NOT WHITE but dark blue, dark green dark red or whatever dark on the black background. http://www.sierrachart.com/image.php?l=1400152432947.png |
[2014-05-15 11:21:34] |
http://www.sierrachart.com/image.php?l=1400152827517.png |
[2014-05-15 11:26:40] |
On the screen image !400152827517 there are white borders between charts. I want no white borders but only dark {whatever color]borders.
[2014-05-15 17:30:00] |
Those borders are provided by the Windows operating system to allow for the chart to be resized. The color has to be changed through the Windows color settings.
