Date/Time: Mon, 17 Mar 2025 02:39:30 +0000
Is their a ways to have more than 1 Linking variable on the chart
View Count: 284
[2022-09-01 00:24:57]
GravisHTG - Posts: 306
EX :
Chart 1 and 2 link is 1
and that link only have Symbol and Scroll Position enable
Then from chart 1 I add Link 2 to link to chart 3
on that link it have bar period and Symbol
Is their a way to do this , As I lots of subchart under my main charts.
thanks
[2022-09-01 00:40:10]
John - SC Support - Posts: 38678
You can not do this in the way you are thinking. But you can accomplish most of this by having all 3 charts set to Link 1 and having the following:
Chart 1 has the following link options enabled:
- Symbol, Scroll Position, Bar period
Then on Chart 2 use the following link options:
Then on Chart 3 use the following link options:
- Symbol, Bar Period
