Date/Time: Tue, 29 Sep 2026 21:12:20 +0000
data or different pack
View Count: 671
[2022-08-31 23:55:30]
gary a thomas - Posts: 2
I am trying to renew my service pack 5 and noticed a message saying I can no longer use CQG data and have to go to service pack 11, I don't see that as a choice to sign up for. So I thought I would look at the Danali data but I can't find a price for it
[2022-09-01 00:31:12]
John - SC Support - Posts: 48062
We are not sure what you mean by "I don't see that as a choice to sign up for."
Package 11, and all the packages are available in the menu for package selections at the following link:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#ServicePackage
Just select the menu for Choose Service Package and Time Period for Usage Time, or "Disabled". You will see all the packages and the different timeframes for which you can make a purchase. You will have a choice of Packages 3, 5, 10, 11, or 12.
If you have an issue with the above, let us know.
The Denali Exchange Data Feed requires that you are on one of the Integrated packages, which are Packages 10, 11, and 12. You also need to be on one of these packages in order to make any external connections for trading or data.
Apart from this, the cost for the Denali Exchange Data Feed is the cost of the exchange(s) themselves. You will find the list of available exchanges and their cost at the following link:
Denali Exchange Data Feed: Supported Exchanges (Exchange Fees)
Also on that page are the Setup Instructions for the Denali Exchange Data Feed. When you are ready, follow the appropriate instructions on that page.
