Date/Time: Mon, 17 Mar 2025 01:16:04 +0000
Edit Watchlist in control bar font is missing or white. How do I find color setting?
View Count: 417
[2022-08-31 22:26:08]
AmberNinja - Posts: 31
I added and "watchlist" window to my control bar. The font is black.
When I edit watchlist and click ADD to add other tickers I dont see any font but it looks like its adding something.
What is wrong?
imageCapture.JPG / V - Attached On 2022-08-31 22:25:14 UTC - Size: 47.9 KB - 130 views
[2022-08-31 22:30:31]
John - SC Support - Posts: 38678
When you type in the symbol at the bottom of the window it should be showing up above at the same time.
Let us know if you are not seeing anything in the field at the bottom when you are entering the symbol name in there.
[2022-09-01 19:22:09]
I figured it out. I didnt know you had to type it in first to locate the ticker when you add. Please close ticked. Thanks.
