Date/Time: Mon, 17 Mar 2025 02:34:27 +0000
Logarithmic Scale
View Count: 396
[2022-08-31 20:23:02]
obee2732 - Posts: 11
I'm not having success turning off the Logarithmic scale on the chart.
I have gone to Chart Setting and Scale tab and for Scale ensured that Linear is clicked
but when I go to Chart menu, and press on Logarithmic, the checkmark continues to be next to Logarithmic
And I'm not able to use CTRL on vertical axis to change the spacing between them.
Thanks for the help
[2022-08-31 20:34:05]
Sierra_Chart Engineering - Posts: 18801
When you select the Chart menu and do not select the Logarithmic Scale command, is there no checkmark by it?
If the Logarithmic Scale command on the menu is checked, select it again and then it will be unchecked and the chart should no longer be using a logarithmic scale.
[2022-08-31 20:38:35]
When I select Chart menu, Logarithmic Scale has a checkmark left of it.
When I select Logarithmic Scale in order to un-check it, even though I have clicked on it, the checkmark remains present to the left of Logarithmic Scale
It is rather odd
[2022-08-31 22:19:13]
John - SC Support - Posts: 38678
Do you have any special studies on this chart, particularly third party studies that may be forcing the logarithmic scaling?
Otherwise, we can not think of any reason why you can not undo the logarithmic scaling. Selecting the option Chart >> Logarithmic Scale should take care of it.
Do you have this issue with any other charts? If you start a new chart for the same symbol is it a linear (normal) scale?
