Date/Time: Sun, 20 Sep 2026 23:15:32 +0000
Why aren't all InteractiveBroker product symbols automatically available on SIerra????
View Count: 1400
[2014-05-14 12:25:14]
User59863 - Posts: 36
Where's DKK crosses in Forex (Interactivebrokers)? This is just ONE instance of a symbol available but unavailable on SIerra under "Find Symbol"
Oh dear, Sierra sleeping on the job again with not available symbols in "Find Symbol" database?
Why aren't all IB product symbols automatically available on SIerra????
Can you do something about it from an archtecture POV - something ain't right....
Instead of me having to request each & every not-available stocks, futures, FX symbol?
[2014-05-14 16:41:36]
As far as adding all Interactive Brokers symbols listed with the proper settings, that is a monumental task. That would be a very inefficient use of our time and we would not allocate that kind of time to something this. Additional symbols would only be added on request.
And in no case would we ever list stock symbols. There are too many of them and they change.
You can also add symbols yourself through the Global Symbol Settings:
http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php
And you can also just manually type in a symbol. Refer to this page:
http://www.sierrachart.com/index.php?l=doc/IBSymbols.html
[2014-05-14 16:43:21]
We will be adding the DKK CASH symbols in about 20 minutes.
To get them you just need to restart Sierra Chart.
