Date/Time: Mon, 17 Mar 2025 01:13:23 +0000
Position line shows only Quantity, nothing else
View Count: 565
[2022-08-31 19:18:39] |
User368639 - Posts: 45 |
I have spent all day trying to resolve this issue, using all your resources, to no avail. I have two instances running and the Position line in the Second Instance is just as it should be. I have set Global Chart Trading in each instance side by side and have the First Instance set up exactly like the Second Instance. It worked fine yesterday so I surely have checked or unchecked something. Restarted computer. Closed and re-opened Trade Window for chart. I have checked the box which says to use Global Settings instead of Chart Graphics Settings. I have gone through your documentaion to the letter. Please advise. Thank you. |
[2022-08-31 19:59:14] |
Sierra_Chart Engineering - Posts: 18801 |
Provide an image of the chart or Trade DOM showing specifically what you are asking about, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-31 21:12:50] |
My error for not scrolling down and seeing this earlier. Apologies for creating a new ticket. https://www.sierrachart.com/image.php?Image=1661978944192.png |
[2022-08-31 22:23:20] |
John - SC Support - Posts: 38678 |
The settings that control the information in the position line are in Trade >> Chart Trade Settings >> Working Orders. Refer to the information starting here: Global Trade Settings Windows: Working Orders (Global Settings >> Chart Trade Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-01 05:18:16] |
Good morning, John. Yes, I know. This link is Edit > Screen Images > Upload chart with overlays. The overlay is my settings for Working Orders. If this is not correct, please tell me how to upload the Working Orders screen so you can see my settings. https://www.sierrachart.com/image.php?Image=1662009161537.png Thank you. |
[2022-09-01 14:25:59] |
Good morning, John: The screen capture did not work, so here are my Working Order settings, which are identical in the 2nd Instance, which displays all the data Value: Yes, in the Position Line: With both these instances set exactly the same in Global Chart Trade Settings and the box checked that says to use Global settings, I must ask if Global truly does override settings done elsewhere or can there be a setting elsewhere that is prohibiting the data set to Yes from displaying? Order Quantity: Yes Order Price: Yes Order Type: Yes Addnl Order Info: No Order Status: Yes Attached Order P/L: No Filled Quantity: Yes Attached Order P/L Always: No Buy/Sell: Yes Estimated Position: No Order Assoc Lines: Yes Limit Line for Stop-Limit Orders: No Single Character Order Type Names: Yes Thank you. |
[2022-09-01 15:20:03] |
The settings you need to adjust are in Global Settings >> Chart Trade Settings >> Chart Position Line.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-01 15:20:08
