Date/Time: Mon, 17 Mar 2025 02:32:04 +0000
Bracket Orders
View Count: 484
[2022-08-31 14:12:45]
User585993 - Posts: 83
Any reason why the bracket order Stop loss and targets only work in SIM, in live mode only to enter a trade (buy/sell order) but not the stop loss or targets.
[2022-08-31 20:56:03]
John - SC Support - Posts: 38678
As long as the setup is the same between Sim and Live you should have your attached orders showing up in both cases.
First make sure that when you are trading live that the "Use Attached Orders" option is enabled and that your attached orders are setup properly.
Second, if they are not showing up after you place the order, then first ensure that you are viewing the prices at the levels of the attached orders. Then check your Trade >> Trade Service Log to see if the exchange rejected the attached orders for some reason.
[2022-09-01 13:47:39]
I followed your instructions, this is the error I get:
Trade Order Error - CQG order update. Status: REJECTED. Text: The order type is not allowed for the commodity. Internal Order ID: 168111. Service Order ID: 1663217611. Symbol: F.US.MESU22. Account: 1009934 | 2022-09-01 13:40:29.923 *
Trade Order Error - CQG order update. Status: REJECTED. Text: This order was rejected with other order in compound order. Internal Order ID: 168112. Service Order ID: 1663217612. Symbol: F.US.MESU22. Account: 1009934 | 2022-09-01 13:40:29.923 *
TradeActivity files query time: 0.015307 seconds. Entries: 177. Current queries: 1 | 2022-09-01 13:41:20.396
TradeActivity files query time: 0.010467 seconds. Entries: 177. Current queries: 1 | 2022-09-01 13:41:22.183
[2022-09-01 13:50:30]
Sierra_Chart Engineering - Posts: 18801
Make sure you are only using Limit or Stop orders for Attached Orders. Do not use Market if Touched orders.
[2022-09-01 13:59:18]
that solved it!
