Date/Time: Mon, 17 Mar 2025 02:36:50 +0000
No DOM data
View Count: 418
[2022-08-31 12:46:58]
pismo10 - Posts: 164
Using latest version. Worked fine yesterday, this morning no DOM data on Sierra. Using IB for data. Orders still sent to IB standalone TWS when click entered on Sierra DOM but no data showing on DOM.
[2022-08-31 13:10:51]
Connection bar is green and DF: is counting up.
[2022-08-31 13:44:49]
Using subscription #11, do I need 12?
Date Time Of Last Edit: 2022-08-31 13:45:02
[2022-08-31 14:00:10]
12 did not help
[2022-08-31 15:33:40]
Sierra_Chart Engineering - Posts: 18801
First go through the information here:
File Menu: Not Receiving the Full Number of Market Depth Levels
We also set your Service Package back to 11.
[2022-08-31 16:25:56]
File>>Open Mkt Depth Window is all zeros.
No help otherwise.
I get an error msg saying exceeded SC data connections of 3. This copy of Sierra is using IB so dont understand that either. I have two other copies running on this computer that use SC data. Service used is IB (trading). Do they not serve data anymore to the Sierra DOM? The orders still go to IB from the Sierra DOM.
thks
Date Time Of Last Edit: 2022-08-31 16:26:47
[2022-08-31 17:05:23]
Open a chart for the symbol you have an issue with. Tell us that symbol of the chart.
https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog
[2022-08-31 18:24:34]
Sent via "send for analysis"
[2022-09-01 10:57:54]
This is the problem:
SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsForSameDevice = 3, NumCurrentConnectionsForSameDevice = 4 | 2022-08-31 14:22:15.765
Refer to:
Denali Exchange Data Feed: Connections
[2022-09-01 11:38:27]
That fixed it.
In support article, Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds should be
File >> Data/Trade Service Settings >> Common Settings >> Allow Support for Sierra Chart Data Feeds set to No.
