Date/Time: Mon, 17 Mar 2025 01:13:23 +0000
Text Labels on horizontal lines
View Count: 407
[2022-08-31 07:11:04] |
User467500 - Posts: 28 |
Hello, is it possible to create horizontal lines with text labels? looking to create horizontal line templates in the drawing tool for lines that i would want to manually draw in for things like equal highs, equal lows, break of structure etc Thanks |
[2022-08-31 11:51:12] |
Sierra_Chart Engineering - Posts: 18801 |
Yes can through the Modify Text function for drawings: Chart Drawing Tools: Modify Text Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-31 11:51:20
[2022-08-31 11:57:10] |
Thanks. Can we create line templates eg a style for Break in Structure , a different one for Buyside Liquidity etc ?. This way when we change the saved template we can change several properties of the line all at once, saving lots of time. Thanks
[2022-08-31 20:45:13] |
John - SC Support - Posts: 38678 |
Refer to the following: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-31 23:18:18] |
thanks.. this answered all my questions..
