Date/Time: Sat, 20 Apr 2024 08:26:14 +0000
Support and Resisitance Levels
View Count: 1846
[2013-04-29 12:25:21] |
Arnold - Posts: 20 |
Do you guys have a way of automatically putting R2 and S2 levels on charts for different instruments. Arnold |
[2013-04-29 16:48:49] |
If you are referring to Pivot Point levels, then use the Pivot Points study.
[2013-04-29 17:15:06] |
Thank you
