Date/Time: Mon, 17 Mar 2025 02:36:48 +0000
Chart same symbol two different time frames
View Count: 374
[2022-08-31 02:38:35] |
User472677 - Posts: 362 |
Is it possible to compare SPY for 2006 - 2008 to SPY for 2021 -2022? Please see below.
Attachment Deleted. Private File |
[2022-08-31 20:44:03] |
John - SC Support - Posts: 38678 |
Yes, you can do this by using the Study/Price Overlay study and setting the Input for Match Source Bars to Destination Bars to No. When you do this, the overlay study overlays bar by bar, starting at the most recent and going backwards. Therefore, you would need to ensure that you have the dates and bar period set precisely in order to get the overlay to occur properly. Refer to the information for this particular Input here: Study/Price Overlay Study: Match Source Bars to Destination Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
