Date/Time: Thu, 24 Sep 2026 14:41:57 +0000
Use trade activity log to test Brackets
View Count: 622
| [2022-08-31 01:08:34] |
| User412102 - Posts: 5 |
Is there a way to use the data from the trade activity log to back-test alternate brackets? I would like to use the entries from my trade activity log over a given date range to test different bracket setups and am trying to figure out an easier way to do it other than manually entering the trades in SIM mode. |
| [2022-08-31 11:36:39] |
| Sierra_Chart Engineering - Posts: 24961 |
You can certainly replay that the order fill data and watch the fills if you previously have done trading activity in simulation mode. Refer to: Replaying Charts You can also edit the the fill data before you do replaying. Refer to: Trade Activity Log: Trade Activity Data Editing Menu Commands (Trade >> Trade Activity Log) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-31 11:37:14
| [2022-08-31 13:07:40] |
Thank you that is helpful. Is there any way to use the data from the live trading activity log and input it into some sort of format the software can read to perform a test? |
| [2022-08-31 15:36:01] |
Well if you are looking to do back testing, the method to do this is explained here: Auto Trade System Back Testing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
