Date/Time: Mon, 17 Mar 2025 02:36:49 +0000
Alert above average delta and volume
View Count: 477
[2022-08-30 21:55:02] |
User980952 - Posts: 13 |
Hello, How can I configure an alert to notify me when the volume is above average and also notify me when the delta is above average? The average would be calculated with the RTH session that is under development. I would like to set these alerts on a 5m and 1m chart. Thank you very much. |
[2022-08-31 10:55:30] |
Sierra_Chart Engineering - Posts: 18801 |
You will want to use these studies: Volume Moving Average-Simple. (On a 1 minute chart you can use a Length of about 60. Although this is for you to determine.) And then create a formula to check when the volume is above the moving average. Refer to: Volume Moving Average - Simple Study/Chart Alerts And Scanning Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-31 10:56:14
