Date/Time: Mon, 17 Mar 2025 02:34:29 +0000
How do I get the window that shows all activity when using platform (like save activity)?
View Count: 365
[2022-08-30 20:40:32] |
Samir GFX - Posts: 6 |
Hi I must have closed the window that shows all activity on my platform. Like order fills, connection to exchange and when my chartbook saves? I cant find how to get this window back. Thanks in advance. |
[2022-08-30 21:27:00] |
John - SC Support - Posts: 38678 |
It sounds like you are referring to the Message Log. To open the Message Log select Window >> Message Log. If you do not see the Message Log after selecting the above, then select Window >> Reset Windows and if it is still not there select the option again under the Window menu. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-31 19:35:10] |
Hi John, Thank you it was the message log i was referring to. Problem solved :)
