Date/Time: Thu, 19 Sep 2024 21:27:59 +0000
Re: Error messages
View Count: 932
[2014-05-14 09:15:01] |
User41512 - Posts: 58 |
I have been getting these constant error messages for the last couple of days. I have attached a screen print of part of the error message. All of the other programs/applications have not been affected. Thks Patrick |
Attachment Deleted. Attachment Deleted. 2014-05-14_1013.png / V - Attached On 2014-05-14 09:14:15 UTC - Size: 169.35 KB - 333 views |
[2014-05-14 09:22:31] |
The only line in that log that we consider an error message is where it says the connection timed out. Is that what you are referring to? For a problem like that we recommend exiting the IQ Feed software and allowing Sierra Chart to start it back up again. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
