Date/Time: Sun, 16 Mar 2025 23:45:27 +0000
second computer
View Count: 360
[2022-08-30 18:19:32]
User258414 - Posts: 1
Good day. I can't set up trading from GAIN Capital on the other computer, I don't see anything in the Service Setings settings. On the first computer, everything is fine. Can you please help me?
[2022-08-30 18:58:06]
John - SC Support - Posts: 38678
With version 2417 and above, you can no longer connect to Gain Capital. Make sure the version on the new computer is 2416 or lower.
Refer to the following instructions for how to downgrade your system, if you need to:
Software Download: Full Control Rollback Procedure
