Date/Time: Mon, 17 Mar 2025 01:13:20 +0000
Cant open intradaycharts anymore with CQG
View Count: 449
[2022-08-30 16:53:17]
krypto101 - Posts: 33
I try to open a intraday futures chart, but I get an orange box that states "Data only supported with Sierra chart data feed" and a red box " download failed Historical data only supported w Sierra chart data feed.".
I'm using CQG data and I had an easy time pulling up intraday charts before, but now I cant open charts. I try searching for a similar post but I haven't seen any.
image111.png / V - Attached On 2022-08-30 16:52:25 UTC - Size: 109.5 KB - 91 views
[2022-08-30 18:35:06]
SC Support - Posts: 1941
Hi Chris, I missed you with my call just now, please let me know if I can give you call to speak about those topics?
Regarding your situation, please revert to Sierra Chart Version 2391 in order to continue to get Real-time Data from CQG, for help with the process of reverting to a previous version of Sierra Chart, please see this documentation here:
[2022-08-31 05:12:00]
Thanks for reaching out, I did receive two phone calls from the United Kingdom, but since its long distance I normally wont answer those calls.
I never used version 2391, only used Version 10 (2425 64Bit) and it worked along with CQG. So are you asking me to roll back to an old version of Sierra charts? Not sure what changed with ver 2425
Date Time Of Last Edit: 2022-08-31 05:20:02
imageScreenshot 2022-08-30 221935.png / V - Attached On 2022-08-31 05:19:58 UTC - Size: 225.95 KB - 103 views
[2022-08-31 10:00:25]
Sierra_Chart Engineering - Posts: 18801
Refer to the information here regarding this:
https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2394
Date Time Of Last Edit: 2022-08-31 10:00:53
