Date/Time: Sun, 16 Mar 2025 23:55:15 +0000
Is their a way to automaticly Split our quantity when buying or selling.
View Count: 372
[2022-08-30 16:40:29] |
GravisHTG - Posts: 306 |
Example You input 6 Quantity in the Trade window. When you press buy , 6 order of 1 quantity will be send as buy orders. thanks in advance ! |
[2022-08-30 18:16:37] |
John - SC Support - Posts: 38678 |
There is not a built-in way to do this. You would need to create a custom study to do this for you. Refer to the information starting here: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
