Date/Time: Tue, 26 Nov 2024 13:37:32 +0000
Charts and Trade DOM settings
View Count: 1059
[2014-05-14 06:02:22] |
crazybears - Posts: 314 |
Hi SC Support 1) Does Chart can be set to show start data/date from right side instead to left ? having 4 monitor 27" i would try to see charts on the right monitors in that way , i think i could better visualize them . 2)Can i with ACSIL add buttons to TRADE DOM as customize toolbuttons ? i use detached charts and tools buttons to run automatic buy/sell trading systems , unfortunately they don't work with detached charts . thanks |
[2014-05-14 17:09:39] |
1. No. 2. No, however you can customize buttons on the ToolBar: http://www.sierrachart.com/index.php?l=doc/doc_MouseAndMenuInteractionFromACStudy.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-14 18:08:31] |
1)Ok 2) i already use toolbar buttons with acsil to activate strategy but with detached charts dont work fine when you have time and if doesnt involve too much work could you add option to customize trade dom button thanks |
