Date/Time: Mon, 17 Mar 2025 02:42:18 +0000
Also please contact Sierra support and request they enable PriceSquawk for your Sierra a
View Count: 425
[2022-08-30 08:24:50] |
User39772 - Posts: 311 |
Hello, Graham from PriceSquawk told me to contact Sierra support for requesting to enable PriceSquawk for my Sierra account. Can you do that please ? Regards |
[2022-08-30 15:58:46] |
Sierra_Chart Engineering - Posts: 18801 |
For what exchanges do you want to use with PriceSquawk?
[2022-08-30 16:02:06] |
I want to test it, CME would be sufficient.
[2022-09-01 08:37:44] |
Hello pls. let me know if this is possible and if not why, so that I can report it to PQ. I have a test period at the moment running and need to know if SC and PQ are working together. At the moment I get the following messages from PQ: "Successfully logged onto Sierre DTC Server" According to Graham from PQ after that I should see the Symbols currently loaded into the SC charts, which is not the case. Thus PQ can not play the proper sounds. |
[2022-09-01 08:43:44] |
This is now done for your account for CME symbols.
