Date/Time: Sun, 16 Mar 2025 23:55:16 +0000
I am looking to make a simple moving average of the initial balance
View Count: 416
[2022-08-29 21:24:23] |
coachted - Posts: 381 |
I am looking to make a simple moving average of the initial balance (the hi and low from the 1st hour of trading). Can some please point me in the right direction. Much appreciated
[2022-08-30 15:31:37] |
John - SC Support - Posts: 38678 |
You just add whichever Moving Average study you want and set the "Based On" to the study from which the Initial Balance is being determined. Refer to the following: Chart Studies: Settings and Inputs Tab >> Based On - Basing a Study on Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
