Date/Time: Sun, 16 Mar 2025 19:01:26 +0000
Hide drawings
View Count: 853
[2022-08-29 20:36:01] |
User707307 - Posts: 84 |
Hello, Is there anyway to hide the drawings on one chart without eliminating them? Thank you |
[2022-08-29 20:45:48] |
John - SC Support - Posts: 38678 |
If you are asking if you can hide a chart drawing on one chart but continue to have it show up on another chart, where it was copied to, then the answer is - no, you can not do this. Once you hide a drawing, it is hidden on all charts that reference that same drawing.
[2022-08-29 20:49:56] |
And to hide in all charts, but not eliminating it?
[2022-08-29 21:19:11] |
JohnR - User831573 - Posts: 320 |
There is a menu item, if you right click on the drawn item, then near the bottom of the popup menu. Or you can bring up the Manage drawing from the Tools menu and then Hide / unhide from there. Hope this helps, JohnR |
[2022-08-30 15:29:54] |
As JohnR states, if you Hide a drawing in any chart on which it is displayed/copied, it will be hidden on all charts that have that drawing. To Unhide a drawing, you need to use the Tools >> Manage Chart Drawings Window and select your drawing within that and then select "Show" to display it again. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
