Date/Time: Sun, 16 Mar 2025 17:39:26 +0000
[User Discussion] - How to add more A-Z slots in spreadsheet without pushing all equations to the side
View Count: 370
[2022-08-29 19:12:52] |
User773081 - Posts: 26 |
When I go to add "Number Of Formula Columns" it pushes the summation of all equations to the right one slot and destroys the entire sheet. How can I add more Formula Columns without messing up what is already there? Thank you for your time |
[2022-08-29 20:09:50] |
John - SC Support - Posts: 38678 |
In order to prevent this causing trouble in the future, you would want to reference studies within the Spreadsheet by using the nomenclature of [Study ID].[Subgraph number]@[Row number]. Refer to the following: Working with Spreadsheets: References to Study Subgraph Columns when using the Spreadsheet Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
