Date/Time: Tue, 26 Nov 2024 17:17:06 +0000
Intraday Monthly Volume Profile
View Count: 901
[2022-08-29 14:34:11] |
User374621 - Posts: 1 |
Hi, I am having issues trying to create a chart that contains monthly volume profiles. When I use a historical chart, the volume profile is very coarse and not very precise. It seems like the resolution of the profile is not high enough and we notice many strong steps and flat zones. https://www.sierrachart.com/image.php?Image=1661783263450.png Compared to for example my intraday weekly volume profiles as below (VP are much more precise). https://www.sierrachart.com/image.php?Image=1661783317418.png Is there a way to create an intraday monthly volume profile chart? Or is there a way to get the volume profile to be more precise when using a historical chart? Many thanks for your help |
[2022-08-29 14:42:33] |
John - SC Support - Posts: 36300 |
First, refer to the following for why Historical Daily (and higher) timeframe Volume by Price profiles are "coarse": Volume By Price Study: How Volume by Price is Calculated for Historical Daily and Higher Timeframe Charts As referenced in the above, you need to create a chart using the Intraday Only data for whatever timeframe you are wanting in order to get the full data for the Volume by Price profiles. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-11-03 17:26:27] |
jivetrader - Posts: 410 |
Is there a way to create an intraday monthly chart that always starts on the 1st of the month? Specifying 30 or 31 days results in a variable start date for each bar. Thanks
[2023-11-05 18:43:04] |
LudaTrades - Posts: 27 |
(intraday) Chart Settings -> Bar Period Type -> Monthly Bars (second from the bottom of the list) |
[2023-11-05 20:40:30] |
Sierra_Chart Engineering - Posts: 17182 |
Also make sure the session start times are not reversed in this case: Chart Session Times: Why Reverse Session Times? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
