Date/Time: Sun, 16 Mar 2025 17:39:28 +0000
problem with Trading DOM
View Count: 371
[2022-08-29 14:00:09] |
User950788 - Posts: 1 |
Hello, When I began the day all was ok during 5 hours but in just one time all the numbers of the tradind Dom disappeared as well as the columns. I send you a photo of my trading dom. Data feed is ok on the charts and on the market profile. Thanks for your help best regards, MAX |
[2022-08-29 14:24:15] |
Sierra_Chart Engineering - Posts: 18797 |
Reset the scale as explained here: The Chart DOM Scale: Auto Scale the Chart DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
