Date/Time: Sun, 16 Mar 2025 23:55:18 +0000
Market Depth Historical Graph
View Count: 467
[2022-08-29 13:16:19] |
Dorian - Posts: 64 |
Hello. In the study "Market Depth Historical Graph", it would be nice to be able to hide the histories behind the bars. This is possible only for the filling space (Display Market Depth Quantities After Last Bar (In:9)). The goal is therefore to put the same option as In:9, except for the histories. Thanks. Date Time Of Last Edit: 2022-08-29 13:17:39
[2022-08-29 14:52:51] |
John - SC Support - Posts: 38678 |
Sorry, but we are not really understanding what it is that you want to do. Can you please give us some additional information?
[2022-08-29 15:14:15] |
I just wish I could hide the histories behind the bars. See attached image. |
[2022-08-29 16:16:05] |
Thank you for the explanation, we understand perfectly what you are asking for now. As you have found, there is not a way to do this. A workaround, if you are viewing Last data in that area, would be to use the DOM Graph, but it will not have the same range of colors or options. Refer to the following: Chart Settings: Draw DOM Graph On Chart (Chart >> Chart Settings >> Market Depth >> DOM Graph menu) We have set this as a Feature Request. Just keep in mind that we do not know when we can get to any particular feature. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-29 18:21:32] |
Thanks. I'll be patient.
