Date/Time: Mon, 17 Mar 2025 01:18:36 +0000
Not able to see more than 30 bids/offers in DOM
View Count: 554
[2022-08-29 12:28:32] |
User811622 - Posts: 38 |
Is it possible to increase bids/offers to be more than 30 in the DOM? I can see only up to 30.
[2022-08-29 15:08:48] |
John - SC Support - Posts: 38678 |
Refer to the following documentation: File Menu: Not Receiving the Full Number of Market Depth Levels For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-30 03:35:20] |
I looked at the document you sent. It's already set to 0 so should get the max depth but I see only 30 bids/asks max. Is this the maximum that denali has for the DOM? The instrument is F.US.EPU22. Thank you.
[2022-08-30 17:04:49] |
Sierra_Chart Engineering - Posts: 18801 |
You should be seeing now over 900 levels. There are other settings as well. Did you check all of them? There are total of three different settings which affect this.
[2022-08-31 04:57:27] |
Yes, I check them all. They are were already set to 0. Still seeing only 30 depths for each bids/asks. Thanks
[2022-08-31 10:31:36] |
Therefore, we need to do a remote assistance session to determine the problem. Is the telephone number here up to date: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-31 10:31:44
[2022-08-31 13:42:48] |
Yes that number is correct. What number will Sierra Chart be calling from?
[2022-08-31 14:49:36] |
We are not sure how it would show up. It might show as a Wyoming number.
[2022-08-31 15:01:34] |
User has been called and helped. They actually were getting 100 levels of depth, just needed to show them.
