Date/Time: Sun, 16 Mar 2025 23:52:52 +0000
Tpo Profile
View Count: 417
[2022-08-28 13:09:31] |
User557791 - Posts: 7 |
Hi My TPO profile looks weird. I have tried all scaling options, but it dont look right. Can you see what my problem is? |
[2022-08-28 17:08:38] |
Sierra_Chart Engineering - Posts: 18799 |
There are overlapping letters. Refer to: Time Price Opportunity (TPO) Profile Charts: Solving Overlapping TPO Letters Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-28 17:13:07] |
I have Changed the tick size already. It helps, but i need to increase it to a minimum of 40+ Does this affect the functionality in any way when use the profiles in analysis? |
[2022-08-28 18:22:53] |
No. The letters are now based upon 40 ticks.
