Date/Time: Sun, 16 Mar 2025 23:52:53 +0000
Export/Import Data about the tools from the Manage Drawings Window?
View Count: 386
[2022-08-27 14:20:02] |
Jupitersbay - Posts: 54 |
I haven't found a way to export and import the data from the Manage-Drawings-window (as it is possible with the Trade Activity log data). I guess, thats not possible at the moment (without ACSIL), correct? Is this on anybodys wishlist? |
[2022-08-29 07:18:21] |
No, this is not supported.
