Date/Time: Mon, 17 Mar 2025 03:44:44 +0000
trade lines
View Count: 613
[2022-08-27 10:16:07]
Thaddeus Fulmer - Posts: 71
On the order fills, the successful P/L lines are only showing in the color grey while the losing P/L lines are colored Red. My charts used to show Green connecting lines but I can't seem to get them back. It makes for clearer understanding of trades when sharing with others. Thank you.
imageScreen Shot 8-27-2022 at 6.03 AM.png / V - Attached On 2022-08-27 10:15:07 UTC - Size: 131.53 KB - 120 views
imageScreen Shot 8-27-2022 at 6.12 AM.png / V - Attached On 2022-08-27 10:15:11 UTC - Size: 16.96 KB - 108 views
[2022-08-29 09:05:50]
Sierra_Chart Engineering - Posts: 18801
You can control the colors:
Chart Trading and the Chart DOM: Displaying Order Fills on the Chart
[2022-08-29 17:19:37]
I have followed those directions and haven't been able to change the lines to green. It only shows the color RED for a loss and Grey for a profit.
Date Time Of Last Edit: 2022-08-29 17:20:25
imageScreen Shot 8-29-2022 at 1.17 PM.png / V - Attached On 2022-08-29 17:19:57 UTC - Size: 64.31 KB - 102 views
imageScreen Shot 8-29-2022 at 1.16 PM.png / V - Attached On 2022-08-29 17:20:05 UTC - Size: 17.08 KB - 84 views
[2022-08-29 19:38:32]
John - SC Support - Posts: 38678
Refer to Step #12 of the link given above, which gives information on how to change the colors of the Primary and Secondary connecting lines.
If changing the colors does not work, then make sure you are changing the correct Graphics Settings. Refer to the following:
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
