Date/Time: Thu, 19 Sep 2024 21:36:46 +0000
Execution time
View Count: 1004
[2014-05-13 20:20:30] |
Arpad - Posts: 5 |
Dear Sierra Chart, I’m thinking about using Sierra Chart at LMAX Exchange, which has 3 ms execution time. 1) Is the execution time of an order better via Sierra Chart compared to the execution time via MultiCharts? Could you tell me approximate millisecond numbers? 2) Sierra Chart execution time vs. LMAX web GUI execution time? Is there any difference or they are roughly the same? Many thanks for your help. Best regards, Arpad Orfi |
[2014-05-13 20:35:15] |
1. We do not know the answer to this question, but Sierra Chart will transmit the order very fast to the connected trading service. We expect that this would be under 50 µs. 2. We do not know the answer to this question. How could we know? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-05-13 20:35:34
