Date/Time: Sun, 16 Mar 2025 23:55:15 +0000
[User Discussion] - Does Anyone have an MACD that we can choose the MA Type for the FAST , SLOW and MACDma ?
View Count: 439
[2022-08-26 21:01:15]
GravisHTG - Posts: 306
I think Sierra chart does not come with it.
[2022-08-26 22:08:06]
JohnR - User831573 - Posts: 320
I agree that SC does not come with it, but they do provide the source within file Studies3.cpp of the ACS_Source dir that has the code for the MACD. All you would have to do is add 2 more inputs if you wanted the ability to change them, or even simpler, just go to the lines of code that calculate the Fast, Slow and MA and use a different averaging type for each.
Hope this helps,
JohnR
[2022-08-27 00:51:54]
User90125 - Posts: 715
Try this one: Flex MACD
Date Time Of Last Edit: 2022-12-26 21:39:29
