Date/Time: Thu, 19 Sep 2024 22:04:59 +0000
SC v1136 - drawing tools disappear
View Count: 1050
[2014-05-13 19:38:31] |
Trint - Posts: 113 |
Experiencing issues when drawing tools with version 1136. It seems to happen on tools that need a second click to confirm placement so it doesn't happen on text or markers (they seem fine). When drawing fibonacci tools (retracement or extension) the second click makes the horizontal lines disappear, level percentages remain. I reverted back to previous version 1132, and that version worked fine. Then went back to 1136 and again tools disappeared. |
[2014-05-13 20:00:53] |
We cannot duplicate this. We will see what might be causing the problem.
[2014-05-13 20:46:23] |
Al SC Developer - Posts: 434 |
This will be addressed in ver 1137.
