Date/Time: Sat, 12 Sep 2026 20:37:54 +0000
the clock on the graph
View Count: 827
| [2022-08-26 17:03:16] |
| User535254 - Posts: 5 |
I set a clock on the graph but it's not working when it is on a replay mode. It's not working that means the second position is keeping zero and the candle bar doesn't move but the min is working when a min passed and the candle bar moves. So, how to fix it just like on live mode that the second position will count on it? Thanks
| [2022-08-26 17:06:44] |
| Sierra_Chart Engineering - Posts: 24845 |
It sounds like you just have 1 Minute data being replayed. What is the symbol? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2022-08-27 01:21:22] |
Then how to change to 1 second data replay? My symbol is F.US .MHIQ22 Thanks |
| [2022-08-29 09:16:07] |
For now we would recommend using the Sierra Chart Exchange Data Feed and the Hong Kong futures exchange for the market data instead of CQG: Sierra Chart Exchange Data Feed You can still use CQG for order routing.: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
