Date/Time: Sun, 16 Mar 2025 23:57:38 +0000
Cannot connect to SC Data
View Count: 371
[2022-08-26 13:54:31] |
Techotomy - Posts: 104 |
I cannot connect to SC Data: SC Data - All Services | Connecting to the server 127.0.0.1. Port 11099 | 2022-08-26 09:52:48.940 DTC Client socket (1) | Creating socket. | 2022-08-26 09:52:48.940 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-26 09:52:48.940 DTC Client socket (1) | Connecting to IP: 127.0.0.1. | 2022-08-26 09:52:48.940 DTC Client socket (1) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2022-08-26 09:52:50.981 DTC Client socket (1) | CloseSocket call. | 2022-08-26 09:52:50.981 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2022-08-26 09:52:50.981 Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-26 09:52:50.981 DTC Client socket (1) | Closed. | 2022-08-26 09:52:50.981 DTC Client socket (0) | CloseSocket call. | 2022-08-26 09:52:50.997 SC Data - All Services | Disconnected. | 2022-08-26 09:52:50.997 Will reconnect to the server in 2.0 minutes. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-26 09:52:50.997 |
[2022-08-26 14:05:30] |
Sierra_Chart Engineering - Posts: 18801 |
This looks like a sub instance of Sierra Chart but we cannot tell since this is not a complete log. But the reason it cannot connect is simply because the main instance is not running.
[2022-08-26 14:19:33] |
Thanks that was the issue.
