Date/Time: Sun, 16 Mar 2025 23:55:15 +0000
Off Line
View Count: 365
[2022-08-26 11:22:53] |
User936721 - Posts: 16 |
I'm not sure if this is possible but I want to carry on with SIM / Replay work in a few weeks time, but I may be 'off line' at the time I've started a 'replay session' and then gone 'off line (no Wifi)' - and all seems to carry on working (using stored data I assume). But I'm note sure if there are any 'down sides' to running SIM / Replay whilst off line - ie Account trade history etc? Second question - if for some reason I need to restart laptop I know SC will 'logon' to my account - or try to - what happens if I'm off line - will it just terminate - or is there a way to force 'off line use'? Any help greatly appreciated Thanks |
[2022-08-26 13:49:19] |
Sierra_Chart Engineering - Posts: 18800 |
Yes you can definitely do chart replays when off-line. Not a problem. The existing stored data is used. Regarding the other question, refer to: Sierra Chart - Software Login Instructions: Working Off-Line Without an Internet Connection Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-26 13:51:40
