Date/Time: Sun, 27 Sep 2026 11:47:52 +0000
Example ACSIL Study with loop to create subgraphs
View Count: 1643
[2022-08-26 09:08:12]
User92573 - Posts: 616
Dear Support Board,
I'm trying to locate the example study where Sierra shows an ACSIL Study with a loop to create additional subgraphs.
I've looked all through my own example files but cannot remember which Study example demonstrated this code in operation.
Any help appreciated.
Many thanks.
[2022-08-26 10:24:17]
Sierra_Chart Engineering - Posts: 24983
Have a look at this study:
scsf_HorizontalLines
In the /ACS_Source/Studies7.cpp file.
Date Time Of Last Edit: 2022-08-26 10:24:46
[2022-08-29 07:53:09]
Thank you for the pointer and apologies for delayed reply - I had not noticed the response.
That's great, it wasn't the exact example I'd referenced previously but it's a really good memory jogger and exactly what I needed.
Many thanks.
*** UPDATE ***
Brilliant found the code straightaway using "[SubgraphIndex]"
Many thanks.
Date Time Of Last Edit: 2022-08-29 08:02:10
