Date/Time: Sun, 16 Mar 2025 23:55:16 +0000
Multiple Brokers
View Count: 722
[2022-08-26 01:49:37]
SlothicTrader - Posts: 6
Hello, I currently trade via SC using TETON order routing and Ironbeam as my broker. I would like to add another account at a different broker. Will it be possible to simultaneously trade both brokers with my sierrachart account / teton order routing whether that is using the same instance, different instance or different install? Or is the order routing capability a 1:1 relationship?
Thank you!
[2022-08-26 11:20:11]
Sierra_Chart Engineering - Posts: 18800
Yes you can do this. It would be a single instance, if the account is also at Ironbeam. Otherwise separate installations of Sierra Chart.
