Date/Time: Tue, 15 Sep 2026 06:00:47 +0000
Horizontal Ray Tool, Left Aligned Text not visible
View Count: 834
[2022-08-26 00:42:31]
User807771 - Posts: 12
I've been setting up another computer with Sierra. On this machine, when the starting point isn't visible for a Horizontal Ray - the left aligned text isn't visible (I must scroll back to where the ray starts to see the text)? This is not the case on my other machine.
Is there a setting that isn't part of the the Horizontal Ray config that allows for text/price to always be visible?
[2022-08-26 10:42:19]
Sierra_Chart Engineering - Posts: 24868
Make sure the Vertical alignment is not "Center". This is controlled through the Chart Drawing Properties:
Chart Drawing Tools: Chart Drawing Properties
Date Time Of Last Edit: 2022-08-26 10:42:48
