Date/Time: Tue, 13 Oct 2026 14:21:31 +0000
Text Tool features I miss: Faster use of text-tool
View Count: 1029
| [2022-08-25 22:58:34] |
| Jupitersbay - Posts: 54 |
Hi there, I am using the text-tool a lot - and there are a few features I haven`t been able to create so far. Maybe they are there, but I haven't found them: 1) close text-tool-window I have to click "Ok" to close the window. Cannot use Return-key or something else to close the text-tool-window. Does anybody know another way to close the window? Favorite way: Strg + Enter to close text-window 2) Modify text on chart Is there another way than right click - modify text - [change text] - click enter (I guess this has to be done with a ACSIL-script) Favorite way: hotkey + click on text 3) create quick text on chart Favorite way: Ctrl + click on chart > create text there (+close the text-box with strg+enter) Does anybody know ways to work with the text-tool? Thank you, Marlon |
| [2022-08-26 10:45:13] |
| Sierra_Chart Engineering - Posts: 25153 |
1. This is not supported. 2. No other way. 3. You can create a shortcut to select the Text tool: Global Settings Menu: Customize Keyboard Shortcuts (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
