Date/Time: Mon, 14 Sep 2026 08:16:45 +0000
Trades showing in chart
View Count: 652
| [2022-08-25 20:55:35] |
| User624220 - Posts: 7 |
Can't find setting to turn off/on trades displaying in charts? Sorry, been digging but no luck
| [2022-08-26 04:10:14] |
| Tony - Posts: 725 |
Not sure if I understand your question correctly, when chart trade mode is on, there is no way to turn off "show orders and positions", if it really bothers you, you could go: Chart Settings -> Trading -> Trade Drawings Left Align %, and set it to a smaller number
| [2022-08-26 10:39:10] |
| Sierra_Chart Engineering - Posts: 24859 |
If you are referring to order fills, refer to: Chart Trading and the Chart DOM: Displaying Order Fills on the Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
