Date/Time: Mon, 17 Mar 2025 01:10:27 +0000
dom on chart
View Count: 936
[2022-08-25 18:23:25]
User411320 - Posts: 303
how can i get my dom on chart like the image shows
image05-05-2015 18-29-14.png / V - Attached On 2022-08-25 18:23:14 UTC - Size: 207.93 KB - 117 views
[2022-08-25 21:54:15]
Sierra_Chart Engineering - Posts: 18801
This is enabled with this command:
Trade Menu: Trading Chart DOM On (Trade menu)
[2022-09-05 12:47:45]
thanks for that but as you can see in the attached photo, orders are very hard to see, how can I fix that?
Also how can I go back to the default settings of it?
imageScreenshot 2022-09-05 084550_chart dom.png / V - Attached On 2022-09-05 12:47:31 UTC - Size: 47.57 KB - 98 views
[2022-09-06 17:46:52]
John - SC Support - Posts: 38678
You have to work with the colors of the Chart DOM to get it like your first image. Refer to the information for changing Graphics Settings here:
Graphics Settings
