Date/Time: Sun, 16 Mar 2025 20:16:19 +0000
Template Cht how to upload to my chartbooks
View Count: 596
[2022-08-25 18:04:01] |
Daniel Kamiński - Posts: 25 |
Hello, I have a Sierra Chart Template in Cht format and would like to add it to my Chartbooks. How to do it? Regards, Daniel Kamiński |
[2022-08-26 10:26:01] |
Sierra_Chart Engineering - Posts: 18799 |
You need to save the file to the Sierra Chart Data Files Folder. To find that folder, refer to: General Settings Window: Data Files Folder (Global Settings >> General Settings >> Paths >> Files and Folder Paths) And then you can open it normally: Chartbooks (Workspaces): To Open a Chartbook Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-26 10:28:56
