Date/Time: Sun, 16 Mar 2025 23:57:36 +0000
TSLA-NQTV not printing after split
View Count: 396
[2022-08-25 16:36:48]
GlennDB - Posts: 10
TSLA-NQTV not printing after stock split. Can you fix it or is this a Totalview issue.
Have deleted previous data and reloaded but still nothing but price showing in price ladder.
Date Time Of Last Edit: 2022-08-25 16:37:49
[2022-08-25 16:56:36]
lobster2022 - Posts: 1
I'm also seeing this issue but only on intraday data for TSLA-NQTV. Same thing with GOOGL-NQTV since the split
[2022-08-25 17:15:27]
Sierra_Chart Engineering - Posts: 18801
The split adjustment has been performed. However, this would not affect chart updating. So we do not know what the issue is in your case.
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". You just need to do this once per symbol and not for each chart.
[2022-08-25 17:23:37]
GlennDB - Posts: 10
That worked thanks. I had manually deleted them, not sure why that would not have worked but up and running.
